February 20, 2023 at 12:51 PM #19 BTWconnecting from terminal did work.mysql -u kodi -p -h 192.168.0.2
March 2, 2023 at 11:23 AM #20 After much late night messing I've got this working and I like the results.Using a Acer Aspire R3700 with wifi adaptor and LE10 as the server and a Amazon Firestick 3rd Generation using only wifi.1. Install the addon and changed default password both to 'kodi'2. SSH into the server and use a text editor to edit/storage/.kodi/userdata/addon_data/service.mariadb/my.cnfI removed the hash from below on both lines of # skip-grant-tablesuser = rootpid-file = /run/mysqld/mysqld.pidsocket = /run/mysqld/mysqld.sockskip-grant-tables[client]port = 3306socket = /var/run/mysqld/mysqld.sockskip-grant-table3. Installed kodi 19.5 on the firestickadded the below advancedsettings.xml file to BOTH instances of kodi i.e. server and client in the userdata folder.<advancedsettings><videodatabase><type>mysql</type><host>172.20.6.2</host><port>3306</port><user>root</user><pass>kodi</pass></videodatabase><musicdatabase><type>mysql</type><host>172.20.6.2</host><port>3306</port><user>root</user><pass>kodi</pass></musicdatabase><videolibrary><importwatchedstate>true</importwatchedstate><importresumepoint>true</importresumepoint></videolibrary></advancedsettings>4. setup smb on kodi to share files using zeroconf.5. setup video libraries on both client for movies and tvshows and setup and selected the default scraper.and scanned for content.I used user 'root' I probably I could have used user 'kodi' but it's a home media server not an international bank so security is of no issue.
