Add-On Repository Problems 2024/03
  • We are currently having problems with our add-on repository.
    If you have any problems (can't download add-ons, add-on updates are not working etc) with the repository then please let me know here.
    CvH
    March 13, 2024 at 8:16 PM
  • Tried to download TVheadend HTSP client from official libreelec addon repository. Installation fails.
    TVheadend 4.2 service/server download worked.
    libreelec 10.0.4 on Rpi3
    x.x.178.27
    Edited 3 times, last by Astro98 (February 4, 2023 at 2:39 PM).
  • I have the issue. Please see the log below, my ip is x.x.4.144
  • Issue still seems to be present :(
    I.P. X.X.152.148
    Rasberry Pi 3B+
    LibreElec 10.0.4
    Kodi and other Repos work fine.
    kodi.log
  • Still not working, ip address x.x.242.15
    kodi.log errors:
  • I adjusted again and hopefully this is now stabled enough.
    Just to get some background, we are facing some kodi bug that creates a lot connections and A LOT traffic so we try to workaround to minimize the impact.
  • Edit 08/02/2023 14:46 : Working ATM.
    Hello
    Problem still on going.
    Ip : x.x.232.32
    Edited once, last by Nickoos: Adding ETA (February 8, 2023 at 1:46 PM).
  • LibreELEC 10.4 on a PC machine. Currently I can install any Kodi addons, but cannot enter LibreELEC Add-ons repository at all, says "Could not connect to repository". My IP is xxx.xxx.196.140.
    Before that I had an "installation failed" error on most LibreELEC add-ons (Chrome and System-tools would fail, but for some reason I was able to install everything from the Audio encoders section). I reinstalled the system since then, didn't realise it wasn't a problem on my side. I do remember seeing the 429 error for Chrome installation in the logs and error (22) for system-tools
    Here are the logs: http://ix.io/4nLh
  • So seems like there's a daily quota for addon installs, and it's fairly low. Today I've managed to install Chrome, enable Linuxserver.io repos and installed under a dozen emulators before I started getting installation fails again.
    I mean, normally it would be okay, but I did a fresh install just yesterday, so there are quite a few things I wanted to set up.
