Beelink A1 problems with USB3.0 and power off/on
  • Hello,
    I want to use LE on my Beelink A1. I tried LE10.0.1 and nightly images. With both images the USB3.0 port doesn't find attached devices. It seams that there is no 5V power supply at this port.
    Another problem is that I can't power on the device after shutdown using the IR remote. I must disconnect and reconnect the power supply to start it agein.
    The RTL8821CU wifi module doesn't work.
    Are these problems know an can somehow be solved?
