I cannot download from official repo...
2021-10-26 09:36:18.188 T:3975152496 ERROR: CCurlFile::FillBuffer - Failed: SSL peer certificate or SSH remote key was not OK(60)
2021-10-26 09:36:18.189 T:3975152496 ERROR: CCurlFile::Open failed with code 0 for https://mirrors.kodi.tv/addons/leia/metadata.common.fanart.tv/metadata.common.fanart.tv-3.6.3.zip:
2021-10-26 09:36:18.189 T:3975152496 ERROR: Could not fetch addon location and hash from https://mirrors.kodi.tv/addons/leia/metadata.common.fanart.tv/metadata.common.fanart.tv-3.6.3.zip
all log here...
2015-01-01 01:00:16.315 T:4093157392 NOTICE: -----------------------------------------------------------------------
2015-01-01 01:00:16.315 T:4093157392 NOTICE: Starting Kodi (18.2 Git:18.2-Leia). Platform: Linux ARM 32-bit
2015-01-01 01:00:16.315 T:4093157392 NOTICE: Using Release Kodi x32 build
2015-01-01 01:00:16.315 T:4093157392 NOTICE: Kodi compiled 2019-05-04 by GCC 8.2.0 for Linux ARM 32-bit version 3.14.29 (200221)
2015-01-01 01:00:16.315 T:4093157392 NOTICE: Running on LibreELEC (official): 9.0.2, kernel: Linux ARM 64-bit version 3.14.29
2015-01-01 01:00:16.315 T:4093157392 NOTICE: FFmpeg version/source: 4.0.3-Kodi
2015-01-01 01:00:16.315 T:4093157392 NOTICE: Host CPU: AArch64 Processor rev 4 (aarch64), 4 cores available
2015-01-01 01:00:16.315 T:4093157392 NOTICE: ARM Features: Neon enabled
2015-01-01 01:00:16.315 T:4093157392 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi/
2015-01-01 01:00:16.315 T:4093157392 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
2015-01-01 01:00:16.315 T:4093157392 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/kodi/addons
2015-01-01 01:00:16.315 T:4093157392 NOTICE: special://masterprofile/ is mapped to: /storage/.kodi/userdata
2015-01-01 01:00:16.315 T:4093157392 NOTICE: special://envhome/ is mapped to: /storage
2015-01-01 01:00:16.315 T:4093157392 NOTICE: special://home/ is mapped to: /storage/.kodi
2015-01-01 01:00:16.315 T:4093157392 NOTICE: special://temp/ is mapped to: /storage/.kodi/temp
2015-01-01 01:00:16.316 T:4093157392 NOTICE: special://logpath/ is mapped to: /storage/.kodi/temp
2015-01-01 01:00:16.316 T:4093157392 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
2015-01-01 01:00:16.316 T:4093157392 NOTICE: Local hostname: LibreELEC-hub
2015-01-01 01:00:16.316 T:4093157392 NOTICE: Log File is located: /storage/.kodi/temp/kodi.log
2015-01-01 01:00:16.316 T:4093157392 NOTICE: -----------------------------------------------------------------------
2015-01-01 01:00:16.325 T:4093157392 INFO: loading settings
2015-01-01 01:00:16.327 T:4093157392 NOTICE: special://profile/ is mapped to: special://masterprofile/
2015-01-01 01:00:16.352 T:4093157392 DEBUG: CSkinSettings: no <skinsettings> tag found
2015-01-01 01:00:16.352 T:4093157392 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
2015-01-01 01:00:16.355 T:4093157392 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
2015-01-01 01:00:16.355 T:4093157392 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="utf-8" ?>
<advancedsettings>
<cputempcommand>/usr/bin/cputemp</cputempcommand>
<gputempcommand>/usr/bin/gputemp</gputempcommand>
<showexitbutton>false</showexitbutton>
<remotedelay>1</remotedelay>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
</advancedsettings>
2015-01-01 01:00:16.356 T:4093157392 WARNING: CSettingsManager: missing version attribute
2015-01-01 01:00:16.357 T:4093157392 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
2015-01-01 01:00:16.357 T:4093157392 NOTICE: Default Video Player: VideoPlayer
2015-01-01 01:00:16.357 T:4093157392 NOTICE: Default Audio Player: paplayer
2015-01-01 01:00:16.357 T:4093157392 NOTICE: Disabled debug logging due to GUI setting. Level 0.
2015-01-01 01:00:16.357 T:4093157392 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
2015-01-01 01:00:16.516 T:4093157392 NOTICE: PulseAudio: Server found running - will try to use Pulse
2015-01-01 01:00:16.535 T:4093157392 NOTICE: Running database version Addons27
2015-01-01 01:00:16.636 T:4093157392 NOTICE: ADDON: audioencoder.kodi.builtin.aac v1.0.0 installed
2015-01-01 01:00:16.636 T:4093157392 NOTICE: ADDON: audioencoder.kodi.builtin.wma v1.0.0 installed
2015-01-01 01:00:16.636 T:4093157392 NOTICE: ADDON: driver.dvb.crazycat_aml v9.0.0 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: game.controller.default v1.0.8 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: game.controller.snes v1.0.8 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: kodi.binary.global.audioengine v1.0.1 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: kodi.binary.global.filesystem v1.0.2 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: kodi.binary.global.general v1.0.3 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: kodi.binary.global.gui v5.12.0 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: kodi.binary.global.main v1.0.14 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: kodi.binary.global.network v1.0.0 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: kodi.binary.instance.audiodecoder v2.0.0 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: kodi.binary.instance.audioencoder v2.0.0 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: kodi.binary.instance.game v1.1.0 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: kodi.binary.instance.imagedecoder v2.0.0 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: kodi.binary.instance.inputstream v2.0.8 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: kodi.binary.instance.peripheral v1.3.7 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: kodi.binary.instance.pvr v5.10.3 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: kodi.binary.instance.screensaver v2.0.0 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: kodi.binary.instance.vfs v2.0.0 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: kodi.binary.instance.videocodec v1.0.1 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: kodi.binary.instance.visualization v2.0.1 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: kodi.resource v1.0.0 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: metadata.album.universal v3.1.1 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: metadata.artists.universal v4.3.0 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: metadata.common.allmusic.com v3.2.0 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: metadata.common.fanart.tv v3.6.1 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: metadata.common.imdb.com v3.1.4 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: metadata.common.musicbrainz.org v2.2.1 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: metadata.common.theaudiodb.com v2.0.2 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: metadata.common.themoviedb.org v3.1.9 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: metadata.local v1.0.0 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: metadata.themoviedb.org v5.1.7 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: metadata.tvshows.themoviedb.org v3.1.0 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: os.libreelec.tv v9.0 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: os.openelec.tv v9.0 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: peripheral.joystick v1.4.7 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: repository.kodi.game v1.0.0 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: repository.libreelec.tv v9.0.1 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: repository.xbmc.org v3.1.5 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: resource.images.weathericons.default v1.1.8 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: resource.language.en_gb v2.0.1 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: resource.uisounds.kodi v1.0.0 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: screensaver.xbmc.builtin.black v1.0.32 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: screensaver.xbmc.builtin.dim v1.0.54 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: script.module.pil v1.1.7 installed
2015-01-01 01:00:16.637 T:4093157392 NOTICE: ADDON: script.module.pycryptodome v3.4.3 installed
2015-01-01 01:00:16.638 T:4093157392 NOTICE: ADDON: script.program.driverselect v0.1.6 installed
2015-01-01 01:00:16.638 T:4093157392 NOTICE: ADDON: service.libreelec.settings v9.0.0 installed
2015-01-01 01:00:16.638 T:4093157392 NOTICE: ADDON: skin.estuary v2.0.22 installed
2015-01-01 01:00:16.638 T:4093157392 NOTICE: ADDON: webinterface.default v18.x-2.4.6 installed
2015-01-01 01:00:16.638 T:4093157392 NOTICE: ADDON: xbmc.addon v18.2.0 installed
2015-01-01 01:00:16.638 T:4093157392 NOTICE: ADDON: xbmc.core v0.1.0 installed
2015-01-01 01:00:16.638 T:4093157392 NOTICE: ADDON: xbmc.gui v5.14.0 installed
2015-01-01 01:00:16.638 T:4093157392 NOTICE: ADDON: xbmc.json v10.3.0 installed
2015-01-01 01:00:16.638 T:4093157392 NOTICE: ADDON: xbmc.metadata v2.1.0 installed
2015-01-01 01:00:16.638 T:4093157392 NOTICE: ADDON: xbmc.python v2.26.0 installed
2015-01-01 01:00:16.638 T:4093157392 NOTICE: ADDON: xbmc.webinterface v1.0.0 installed
2015-01-01 01:00:16.663 T:4093157392 ERROR: DBus error: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
2015-01-01 01:00:16.702 T:4073354096 WARNING: Pulseaudio module module-allow-passthrough not loaded - opening PT devices might fail
2015-01-01 01:00:16.703 T:4073354096 NOTICE: Found 2 Lists of Devices
2015-01-01 01:00:16.703 T:4073354096 NOTICE: Enumerated ALSA devices:
2015-01-01 01:00:16.703 T:4073354096 NOTICE: Device 1
2015-01-01 01:00:16.704 T:4073354096 NOTICE: m_deviceName : default
2015-01-01 01:00:16.704 T:4073354096 NOTICE: m_displayName : Default (AML-M8AUDIO Analog)
2015-01-01 01:00:16.704 T:4073354096 NOTICE: m_displayNameExtra:
2015-01-01 01:00:16.704 T:4073354096 NOTICE: m_deviceType : AE_DEVTYPE_PCM
2015-01-01 01:00:16.704 T:4073354096 NOTICE: m_channels : FL, FR, UNKNOWN1, LFE, BL, BR, FC, BC, BLOC, BROC
2015-01-01 01:00:16.704 T:4073354096 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000
2015-01-01 01:00:16.704 T:4073354096 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
2015-01-01 01:00:16.704 T:4073354096 NOTICE: m_streamTypes : No passthrough capabilities
2015-01-01 01:00:16.704 T:4073354096 NOTICE: Device 2
2015-01-01 01:00:16.704 T:4073354096 NOTICE: m_deviceName : sysdefault:CARD=AMLM8AUDIO
2015-01-01 01:00:16.704 T:4073354096 NOTICE: m_displayName : AML-M8AUDIO
2015-01-01 01:00:16.704 T:4073354096 NOTICE: m_displayNameExtra: Analog
2015-01-01 01:00:16.704 T:4073354096 NOTICE: Device 3
2015-01-01 01:00:16.704 T:4073354096 NOTICE: m_deviceName : hdmi:CARD=AMLM8AUDIO,DEV=0
2015-01-01 01:00:16.704 T:4073354096 NOTICE: m_displayNameExtra: HDMI
2015-01-01 01:00:16.704 T:4073354096 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
2015-01-01 01:00:16.704 T:4073354096 NOTICE: m_channels : FL, FR, BL, BR, FC, LFE, SL, SR
2015-01-01 01:00:16.704 T:4073354096 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_RAW
2015-01-01 01:00:16.704 T:4073354096 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD,STREAM_TYPE_DTSHD_MA,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_EAC3,STREAM_TYPE_TRUEHD
2015-01-01 01:00:16.704 T:4073354096 NOTICE: Enumerated PULSE devices:
2015-01-01 01:00:16.704 T:4073354096 NOTICE: Device 1
2015-01-01 01:00:16.704 T:4073354096 NOTICE: m_deviceName : Default
2015-01-01 01:00:16.705 T:4073354096 NOTICE: m_displayName : Default
2015-01-01 01:00:16.705 T:4073354096 NOTICE: m_displayNameExtra: Bluetooth Audio (PULSEAUDIO)
2015-01-01 01:00:16.705 T:4073354096 NOTICE: m_deviceType : AE_DEVTYPE_PCM
2015-01-01 01:00:16.705 T:4073354096 NOTICE: m_channels : FL, FR
2015-01-01 01:00:16.705 T:4073354096 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
2015-01-01 01:00:16.705 T:4073354096 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
2015-01-01 01:00:16.705 T:4073354096 NOTICE: m_streamTypes : No passthrough capabilities
2015-01-01 01:00:16.761 T:4093157392 ERROR: GetString: error reading /storage/.kodi/userdata/disp_cap
2015-01-01 01:00:16.762 T:4093157392 NOTICE: Found resolution 720 x 480 with 720 x 480 @ 60.000000 Hz
2015-01-01 01:00:16.762 T:4093157392 NOTICE: Found resolution 720 x 480 with 720 x 480 @ 59.940060 Hz
2015-01-01 01:00:16.762 T:4093157392 NOTICE: Found resolution 720 x 576 with 720 x 576 @ 50.000000 Hz
2015-01-01 01:00:16.762 T:4093157392 NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 60.000000 Hz
2015-01-01 01:00:16.762 T:4093157392 NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 59.940060 Hz
2015-01-01 01:00:16.762 T:4093157392 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080i @ 60.000000 Hz
2015-01-01 01:00:16.762 T:4093157392 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080i @ 59.940060 Hz
2015-01-01 01:00:16.762 T:4093157392 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 60.000000 Hz
2015-01-01 01:00:16.762 T:4093157392 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 59.940060 Hz
2015-01-01 01:00:16.762 T:4093157392 NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 50.000000 Hz
2015-01-01 01:00:16.762 T:4093157392 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080i @ 50.000000 Hz
2015-01-01 01:00:16.762 T:4093157392 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 30.000000 Hz
2015-01-01 01:00:16.762 T:4093157392 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 29.970030 Hz
2015-01-01 01:00:16.762 T:4093157392 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 50.000000 Hz
2015-01-01 01:00:16.762 T:4093157392 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 25.000000 Hz
2015-01-01 01:00:16.762 T:4093157392 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 24.000000 Hz
2015-01-01 01:00:16.762 T:4093157392 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 23.976025 Hz
2015-01-01 01:00:16.762 T:4093157392 NOTICE: Found resolution 640 x 480 with 640 x 480 @ 60.000000 Hz
2015-01-01 01:00:16.762 T:4093157392 NOTICE: Found resolution 640 x 480 with 640 x 480 @ 59.940060 Hz
2015-01-01 01:00:16.762 T:4093157392 NOTICE: Found resolution 800 x 600 with 800 x 600 @ 60.000000 Hz
2015-01-01 01:00:16.763 T:4093157392 NOTICE: Found resolution 800 x 600 with 800 x 600 @ 59.940060 Hz
2015-01-01 01:00:16.763 T:4093157392 NOTICE: Found resolution 1024 x 768 with 1024 x 768 @ 60.000000 Hz
2015-01-01 01:00:16.763 T:4093157392 NOTICE: Found resolution 1024 x 768 with 1024 x 768 @ 59.940060 Hz
2015-01-01 01:00:16.763 T:4093157392 NOTICE: Found resolution 1152 x 864 with 1152 x 864 @ 75.000000 Hz
2015-01-01 01:00:16.763 T:4093157392 NOTICE: Found resolution 1280 x 800 with 1280 x 800 @ 60.000000 Hz
2015-01-01 01:00:16.763 T:4093157392 NOTICE: Found resolution 1280 x 800 with 1280 x 800 @ 59.940060 Hz
2015-01-01 01:00:16.763 T:4093157392 NOTICE: Found resolution 1280 x 1024 with 1280 x 1024 @ 60.000000 Hz
2015-01-01 01:00:16.763 T:4093157392 NOTICE: Found resolution 1280 x 1024 with 1280 x 1024 @ 59.940060 Hz
2015-01-01 01:00:16.763 T:4093157392 NOTICE: Found resolution 1440 x 900 with 1440 x 900 @ 60.000000 Hz
2015-01-01 01:00:16.763 T:4093157392 NOTICE: Found resolution 1440 x 900 with 1440 x 900 @ 59.940060 Hz
2015-01-01 01:00:16.763 T:4093157392 NOTICE: Found resolution 1600 x 900 with 1600 x 900 @ 60.000000 Hz
2015-01-01 01:00:16.763 T:4093157392 NOTICE: Found resolution 1600 x 900 with 1600 x 900 @ 59.940060 Hz
2015-01-01 01:00:16.763 T:4093157392 NOTICE: Found resolution 1680 x 1050 with 1680 x 1050 @ 60.000000 Hz
2015-01-01 01:00:16.763 T:4093157392 NOTICE: Found resolution 1680 x 1050 with 1680 x 1050 @ 59.940060 Hz
2015-01-01 01:00:16.763 T:4093157392 NOTICE: Found resolution 1366 x 768 with 1366 x 768 @ 60.000000 Hz
2015-01-01 01:00:16.763 T:4093157392 NOTICE: Found resolution 1366 x 768 with 1366 x 768 @ 59.940060 Hz
2015-01-01 01:00:16.763 T:4093157392 NOTICE: Found (1920x1080@60.000000) at 23, setting to RES_DESKTOP at 16
2015-01-01 01:00:16.781 T:4093157392 NOTICE: EGL_VERSION = 1.4 Linux-r5p1-01rel0
2015-01-01 01:00:16.781 T:4093157392 NOTICE: EGL_VENDOR = ARM
2015-01-01 01:00:16.781 T:4093157392 NOTICE: EGL_EXTENSIONS = EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_KHR_reusable_sync EGL_KHR_fence_sync EGL_KHR_lock_surface EGL_KHR_lock_surface2 EGL_EXT_create_context_robustness EGL_ANDROID_blob_cache EGL_KHR_create_context
2015-01-01 01:00:16.781 T:4093157392 NOTICE: EGL_CLIENT_EXTENSIONS = NULL
2015-01-01 01:00:16.782 T:4093157392 NOTICE: Checking resolution 16
2015-01-01 01:00:17.008 T:4093157392 NOTICE: GL_VENDOR = ARM
2015-01-01 01:00:17.008 T:4093157392 NOTICE: GL_RENDERER = Mali-450 MP
2015-01-01 01:00:17.008 T:4093157392 NOTICE: GL_VERSION = OpenGL ES 2.0
2015-01-01 01:00:17.008 T:4093157392 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
2015-01-01 01:00:17.008 T:4093157392 NOTICE: GL_EXTENSIONS = GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_compressed_ETC1_RGB8_texture GL_EXT_compressed_ETC1_RGB8_sub_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug GL_ARM_shader_framebuffer_fetch GL_ARM_shader_framebuffer_fetch_depth_stencil GL_OES_mapbuffer
2021-10-26 09:35:11.851 T:4093157392 WARNING: CLangInfo: could not find language add-on 'resource.language.pl_pl', loading default..
2021-10-26 09:35:11.959 T:3985634160 NOTICE: Running database version Addons27
2021-10-26 09:35:11.961 T:3985634160 NOTICE: Running database version ViewModes6
2021-10-26 09:35:11.963 T:3985634160 NOTICE: Running database version Textures13
2021-10-26 09:35:11.970 T:3985634160 NOTICE: Running database version MyMusic72
2021-10-26 09:35:11.982 T:3985634160 NOTICE: Running database version MyVideos116
2021-10-26 09:35:11.985 T:3985634160 NOTICE: Running database version TV32
2021-10-26 09:35:11.986 T:3985634160 NOTICE: Running database version Epg12
2021-10-26 09:35:11.989 T:4093157392 NOTICE: start dvd mediatype detection
2021-10-26 09:35:12.034 T:4093157392 NOTICE: load skin from: /usr/share/kodi/addons/skin.estuary (version: 2.0.22)
2021-10-26 09:35:12.579 T:4093157392 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
2021-10-26 09:35:12.665 T:4093157392 NOTICE: Register - new keyboard device registered on application->keyboard: Keyboard (0000:0000)
2021-10-26 09:35:12.666 T:4093157392 NOTICE: Register - new mouse device registered on application->mouse: Mouse (0000:0000)
2021-10-26 09:35:12.671 T:4093157392 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
2021-10-26 09:35:12.673 T:4093157392 NOTICE: Loaded playercorefactory configuration
2021-10-26 09:35:12.673 T:4093157392 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
2021-10-26 09:35:12.673 T:4093157392 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
2021-10-26 09:35:12.701 T:4093157392 NOTICE: initialize done
2021-10-26 09:35:12.701 T:4093157392 NOTICE: Running the application...
2021-10-26 09:35:12.706 T:4093157392 NOTICE: starting zeroconf publishing
2021-10-26 09:35:12.707 T:4093157392 NOTICE: CWebServer[8080]: Started
2021-10-26 09:35:12.707 T:3874440048 NOTICE: ES: Starting UDP Event server on port 9777
2021-10-26 09:35:12.708 T:3874440048 NOTICE: UDP: Listening on port 9777 (ipv6 : false)
2021-10-26 09:35:12.838 T:3949974384 NOTICE: Register - new cec device registered on cec->AOCEC: CEC Adapter (0000:0000)
2021-10-26 09:36:18.189 T:3975152496 ERROR: CAddonInstallJob[metadata.common.fanart.tv]: failed to resolve addon install source path
Display More
