IAGL - dependency on script.module.archive_tool not satisfied
  • EDIT
    markes as solved, i did a soft reset of Libreelec (I started having issues also with youtube addon)
    now IAGL isntalled fine
    thanks
    Hi all,
    I must confess that I probably put myself in this place all by myself...so apologies for wasting your time...
    i was running libreelec 9.2 on my raspberrypi 4 when i decided to move to 10
    silly me instead of going for the 9.97.1 RC1 i somehow downloaded libreelec 11 builds..
    I have now downgraded to 10 by dropping 9.91.1 in the .update folder
    all works apart from IAGL which cannot be installed because " dependency on script.module.archive_tool" not being satisfied
    is there anyone that can provide some help?
    thanks a lot
    M
    Edited once, last by mcarni: solved (August 26, 2021 at 8:40 PM).
