Overall performance of NAND storage vs. micro SD vs. USB stick ?
  • Uff, thanks a lot
    for SD settings went back. To copy it to nand same use below? (or change to .kodi.new instad of.kodi.bak?)?
    Then :
    # systemctl stop kodi
    # mv /storage/.kodi /storage/.kodi.bak
    # cp -av /var/media/DISK/.kodi /storage
    # umount /var/media/DISK
    # systemctl start kodi
  • I think the same path
    mqueue on /dev/mqueue type mqueue (rw,relatime)
    configfs on /sys/kernel/config type configfs (rw,relatime)
    /dev/mmcblk1p2 on /var/media/DISK type ext4 (rw,nosuid,nodev,noexec,noatime,data =ordered)
  • Indeed :)
    You can then go on with these commands :
    # mv /storage/.kodi /storage/.kodi.NAND
  • You're welcome :)
    Next build will certainly include the new "installtointernal" script, which will do the job (if wanted) :
    "Do you want to copy your user data to internal data partition? [Y/n] "
  • That would be great for all I think. When I send instaltointernal i thought I will get whole system with my settings after booting from nand. So first when booted from nand it was panic my settings gone.
    That is really great idea for new biuilts to make such script especially for newbies as me.
    Anyway thank Fredouye for hel and kszaq for great work!
