Hello,
I was not sure where to put my question, feel free to move this thread...
My question is related to FFMPEG that LibreElec is using. I have a Raspberry Pi 4 with official Raspberry OS.
In short - I am trying to achieve realtime transcoding of a HEVC video stream to H264. And for this I need hardware acceleration of both HEVC decoding and H264 encoding.
Unfortunatelly, the current stock FFMPEG provided with Raspberry OS only supports HW accelerated H264 encoding using h264_omx encoder. It also has h264_v4l2m2m encoder, but it produces video with a green tint (bug?). And regarding HEVC - I was not able to enable HW acceleration for it.
I have read that LibreElec uses a custom patched version of FFMPEG and supports HEVC HW accelerated decoding.
So I tried to make my own build of ffmpeg based on LibreElec. And now here is the part where I am failing ![]()
I investigated LibreElec build system (mainly LibreELEC.tv/gen-patches.sh at master · LibreELEC/LibreELEC.tv · GitHub).
I used FFMPEG sources from Kodi(XBMC) branch 4.3.1-Matrix-Alpha1-1 from GitHub - xbmc/FFmpeg: mirror of git://source.ffmpeg.org/ffmpeg.git.
Then I merged GitHub - jc-kynesim/rpi-ffmpeg: FFmpeg work for RPI (branch test/4.3/kodi_main), GitHub - lrusak/FFmpeg: mirror of git://source.ffmpeg.org/ffmpeg.git (v4l2-drmprime-v5) and GitHub - LibreELEC/FFmpeg (branch 4.3-libreelec-misc).
Then I configured build according to package.mk:
./configure --prefix="/usr" \
--cpu=cortex-a7 \
--arch=armv6t2 \
--target-os="linux" \
--disable-shared \
--disable-rpi \
--enable-sand \
--enable-hwaccels \
--disable-hwaccel=h264_v4l2request \
--disable-hwaccel=mpeg2_v4l2request \
--disable-hwaccel=vp8_v4l2request \
--disable-hwaccel=vp9_v4l2request \
--enable-libudev \
--enable-v4l2-request \
--enable-libdrm \
--enable-v4l2_m2m \
--enable-gpl \
--disable-version3 \
--enable-avdevice \
--enable-avcodec \
--enable-avformat \
--enable-swscale \
--enable-postproc \
--enable-avfilter \
--enable-libx264 \
--enable-libx265
Display More
and succesfully builded FFMPEG.
The resulting FFMPEG however does not work as expected
For some reason I get these errors:
[h264_v4l2m2m @ 0x23bdd70] All capture buffers returned to userspace. Increase num_capture_buffers to prevent device deadlock or dropped packets/frames.
And it also seems that HW acceleration of HEVC decoding is not working either.
My FFMPEG command line is:
./ffmpeg -hwaccel drm -c:v hevc -i Udalosti.ts -c:v h264_v4l2m2m -c:a copy -b:v 1500k -pix_fmt yuv420p Udalosti.avi
I am pretty sure that I am doing something wrong, as I am not an expert...
Can someone please point me to the right direction, what might be wrong?
Or if there is another way... I just need HEVC -> H264 HW transcoding of a video stream through pipes.
Thank you very much for any useful info.
