October 25, 2020 at 2:24 PM #1 Hi All,As the subject says, for LE 2 channel stereo listening, should the audio pass-through be disabled or enabled ?is it just enough to select the audio device for the dac or USB spdif to send the signal ?
October 25, 2020 at 6:05 PM #2 For 2ch/stereo keep passthrough disabled.Passthrough is only needed if you connect a DTS/AC3 capable multichannel receiver via S/PDIF and want to be able to play back DTS/AC3 5.1.so long,Hias
October 26, 2020 at 9:28 AM #3 Quote from HiassofT For 2ch/stereo keep passthrough disabled. Passthrough is only needed if you connect a DTS/AC3 capable multichannel receiver via S/PDIF and want to be able to play back DTS/AC3 5.1. so long, Hias HiassofT Thank you..
