I have Beelink GT1 Ultimate tv box. One day some app froze and I turned power off and on. After turning power on, I had no signal on TV and it’s been like that ever since. I contacted Beelink and they gave different 2 images (GT1_709D0.img and GT1_708D0) to try flashing with USB Burning Tool. However, USB Burning Tool always gets stuck at 7% formatting with the following error:
Code:
I tried every possible combination (different ports, power on/no power after reset, force erase, etc). The only positive is that the box is detected by USB Burning Tool.
I also tried making bootable sd card with Burn card maker using those images but it didn’t help either – UART output provided.
Can someone tell me based on the UART logs below what is going on and suggest steps to debug/resolve it?
The interesting part is that every time UART output stops at these two lines and when I googled those lines, it seems other people tv boxes logs, where I found these lines, there is more output following them but in my case it always stops at those lines:
Code:
emmc/sd response timeout, cmd8, status=0x1ff2800
emmc/sd response timeout, cmd55, status=0x1ff2800
Here is the UART output with normal operation – endless loop:
Code:
GXM:BL1:dc8b51:76f1a5;FEAT:ADFC318C:80;POC:3;RCY:0;EMMC:0;READ:800;SD:800;USB:8;LOOP:1;EMMC:0;READ:800;SD:800;USB:8;
Here is the UART output when trying to flash with USB Burning Tool:
Code:
GXM:BL1:dc8b51:76f1a5;FEAT:ADFC318C:80;POC:3;RCY:0;EMMC:0;READ:800;SD:800;USB:8;0.0;
TE: 1981641
BL2 Built : 20:32:17, Sep 8 2017.
gxl g6296b83 - xiaobo.gu@droid12
set vdd cpu_a to 1120 mv
set vdd cpu_b to 1050 mv
set vddee to 1000 mv
Board ID = 12
CPU clk: 1200MHz
BL2 USB
DQS-corr enabled
DDR scramble enabled
STICKY_REG0: 0x00000000
STICKY_REG1: 0x00000000
STICKY_REG9: 0x00000000
DDR3 chl: Rank0+1 @ 912MHz - PASS
Rank0: 1024MB(auto)-2T-13
Rank1: 1024MB(auto)-2T-13
0.0;
TE: 2129485
Board ID = 12
CPU clk: 1200MHz
BL2 USB
0.0;
TE: 2192478
Board ID = 12
CPU clk: 1200MHz
BL2 USB
Load fip header from USB, src: 0x0000c000, des: 0x01400000, size: 0x00004000
New fip structure!
Load bl30 from USB, src: 0x00010000, des: 0x01100000, size: 0x0000d600
Load bl31 from USB, src: 0x00020000, des: 0x05100000, size: 0x0002c600
Load bl33 from USB, src: 0x00050000, des: 0x01000000, size: 0x00065800
NOTICE: BL3-1: v1.0(release):a625749
NOTICE: BL3-1: Built : 11:25:15, Aug 25 2017
NOTICE: BL31: BL33 decompress pass
mpu_config_enable:ok
[Image: gxl_v1.1.3243-377db0f 2017-09-07 11:28:58 qiufang.dai@droid07]
OPS=0x82
wdt: reset registers!
c4 68 a7 67 35 33 5f ce 11 6f 7c e2 [2.436513 Inits done]
secure task start!
high task start!
low task start!
ERROR: Error initializing runtime service opteed_fast
U-Boot 2015.01-ge6b8bc9 (May 05 2018 - 10:41:07)
DRAM: 3 GiB
Relocation Offset is: 76eb4000
[MSG]MMC init in usb
aml_priv->desc_buf = 0x0000000073eb4640
aml_priv->desc_buf = 0x0000000073eb6960
SDIO Port B: 0, SDIO Port C: 1
InUsbBurn
[MSG]sof
Set Addr 6
Get DT cfg
Get DT cfg
Get DT cfg
set CFG
Get DT cfg
Get DT cfg
Get str 300
Get DT cfg
Get DT cfg
Get str 300
Get DT cfg
Get DT cfg
ID[16]
tplcmd[ echo 12345]
12345
[MSG]ret = 0
[info]success
BULKcmd[ low_power]
[info]success
ID[16]
tplcmd[ download mem dtb normal 141312]
[MSG]Down(mem) part(dtb) sz(0x22800) fmt(normal)
[MSG]totalSlotNum = 0, nextWriteBackSlot 3
[info]success
[MSG]Burn Start...
[MSG]load dt.img to 0x0000000001000000, sz=0x22800
[MSG]Burn complete
BULKcmd[download get_status]
[info]success
BULKcmd[disk_initial 4]
dtb magic 5f4c4d41
Amlogic multi-dtb tool
Multi dtb detected
Multi dtb tool version: v2 .
Support 3 dtbs.
aml_dt soc: gxm platform: q201 variant: 3g
dtb 0 soc: gxm plat: q201 vari: 1g
dtb 1 soc: gxm plat: q201 vari: 2g
dtb 2 soc: gxm plat: q201 vari: 3g
Find match dtb: 2
start dts,buffer=0000000001000000,dt_addr=000000000100b800
Multi dtb detected
Support 3 dtbs.
Find match dtb: 2
parts: 10
00: logo 0000000002000000 1
01: recovery 0000000002000000 1
02: rsv 0000000000800000 1
03: tee 0000000000800000 1
04: crypt 0000000002000000 1
05: misc 0000000002000000 1
06: boot 0000000002000000 1
07: system 0000000080000000 1
08: cache 0000000020000000 2
09: data ffffffffffffffff 4
[MSG]run cmd [store disprotect key; store disprotect hynix]
[store]disprotect key
disprotect hynix
emmc/sd response timeout, cmd8, status=0x3ff2800
emmc/sd response timeout, cmd55, status=0x3ff2800
Display More
Here is the UART output when trying to use bootable SD card:
Code:
GXM:BL1:dc8b51:76f1a5;FEAT:ADFC318C:80;POC:3;RCY:0;EMMC:0;READ:800;SD:0;READ:0;0.0;CHK:0;
no sdio debug board detected
TE: 191592
Board ID = 12
CPU clk: 1200MHz
DQS-corr enabled
DataBus test pass!
AddrBus test pass!
Load fip header from SD, src: 0x0000c200, des: 0x01400000, size: 0x00004000
New fip structure!
Load bl30 from SD, src: 0x00010200, des: 0x01100000, size: 0x0000d600
Load bl31 from SD, src: 0x00020200, des: 0x05100000, size: 0x0002c600
Load bl33 from SD, src: 0x00050200, des: 0x01000000, size: 0x00065800
OPS=0x82
c4 68 a7 67 35 33 5f ce 11 6f 7c e2 [0.543459 Inits done]
secure task start!
high task start!
low task start!
DRAM: 3 GiB
register usb cfg[0][1] = 0000000077f5b0e8
[CANVAS]canvas init
boot_device_flag : 1
set wlan gpio pin 6.
set bluetooth gpio pin 17.
Nand PHY Ver:1.01.001.0006 (c) 2013 Amlogic Inc.
init bus_cycle=6, bus_timing=7, system=5.0ns
reset failed
get_chip_type and ret:fffffffe
chip detect failed and ret:fffffffe
nandphy_init failed and ret=0xfffffff1
MMC: aml_priv->desc_buf = 0x0000000073eb4790
aml_priv->desc_buf = 0x0000000073eb6ab0
Display More
Thanks in advance for your help
