Hi, I would like to report having network problems with my Nettop Asus, with a libreelec 9 system
I tried to do without result:
- change the wifi network card (model AR5B22);
- Enhanced antenna installed.
- set fixed ip;
- update the operating system by installing version 9.2 with kernel 5.0
- cable network card also tested.
Then I installed OpenElec 8 and it started working.
Probably there is an incompatibility of librelec with Asus Eee Box EB1501P.
However, for about a year everything worked properly, so I think it's a problem with some updates.
