Hi, I recently moved to a new installation of LibreELEC on a Pi3B. I'm having issues with the Wireless Access Point losing connection, despite using the same settings as my previous LibreELEC install.
The Pi is connected via Ethernet, on startup the W.A.P is created and works properly, however after a few minutes of usage the internet connection is lost although the W.A.P remains visible. Turning the W.A.P setting off and back on doesn't fix the issue, though turning the wireless settings off+on does reset it.
I've tried using different devices, static IP, reinstalling libreELEC, and installing a lower version with no luck.
LibreELEC (official): 9.1.002 (RPi2.arm) LEAP:~ # dmesg [ 0.000000] Booting - Pastebin.com is the result of running dmesg, I noticed the line "brcmfmac: brcmf_vif_set_mgmt_ie: vndr ie set error : -52" although I have no idea if that's the problem, or how to fix it
Thanks for any help!
