RasPi4, Harmony Ultimate and MS eHome IR Receiver - missing buttons
  • Config as in the topic. I subbed the RasPi in for a HTPC that's awaiting replacement parts. All look fine, but I've no cursor/direction/arrow keys working.
    The Harmony is configured as per: HOW TO - Configure a Logitech Harmony Remote for Kodi
    It works fine if i plug this IR receiver into any other machine and use this remote.
    I tried adding it through the keymap editor but it wasn't detecting the presses. They are getting sent as the IR receiver is old enough to have a red flash when it receives input, but whatever it's sending for the arrows isn't getting picked up.
    ir-keytable output (in case that's helpful):
    LibreELEC:~ # ir-keytable
    Found /sys/class/rc/rc0/ (/dev/input/event4) with:
    Name: Media Center Ed. eHome Infrared Remote Transceiver (0471:0815)
    Driver: mceusb, table: rc-rc6-mce
    lirc device: /dev/lirc0
    Supported protocols: lirc rc-5 rc-5-sz jvc sony nec sanyo mce_kbd rc-6 sharp xmp imon rc-mm
    Enabled protocols: lirc nec rc-6
    bus: 3, vendor/product: 0471:0815, version: 0x0000
    Repeat delay = 500 ms, repeat period = 125 ms
    Anyone any ideas?
  • Configure your Harmony to use the Microsoft Media Center Remote profile(not MCE keyboard as in the 4-year old kodi forum post) and it will work out of the box.
  • use the Microsoft Media Center Remote profile
    I saw that suggestions a few times, but MyHarmony won't find that, it keeps matching it to 'Media Center PC [Microsoft Windows Media Center]'. Is that what you mean?
    I take it I can keep the old MCE Keyboard one too, as it'll let me map buttons to keys (particularly t, y, and o) that aren't showing up under the Media Center PC one?
  • I saw that suggestions a few times, but MyHarmony won't find that, it keeps matching it to 'Media Center PC [Microsoft Windows Media Center]'. Is that what you mean?
    I don't have a harmony myself and am not too familiar with their config software but "Media Center PC [Microsoft Windows Media Center]" sounds correct to me.
    It'd be better to stay away from the MCE Keyboard profile/protocol, it's not enabled by default in LE and will cause troubles with newer kernels (eg on x86) or when you enable one of the additional DVB driver sets (on any system).
    If you need to (re-)map additional buttons better to it through Kodi's remote.xml (or using the keymap editor addon) or Lircmap.xml.
    See Infrared Remotes [LibreELEC.wiki] LIRC - Official Kodi Wiki and Keymap - Official Kodi Wiki for details.
  • Lucky sod, their config software is up their with printer driver install software from the late 90s :) These aren't presented in a list you can select from, you have to type in what you've got (model numbers work great, generic descriptions not so much), and then it suggests it's nearest match.
    This is my device list, with the new one on the right, in case it helps anyone in future.
    As long as it'll recognise all the button presses now i should be able to re-map what i need. Cheers for the help.
