Audio (PCM) doesn't work property on Odroid C2, works find on Raspberry PI, OSMC, others
  • I'm trying to play vdeo files with AAC and FLAC audio on an Odroid C2 with LibreELEC 9 (although I believe that it was broken on ealier C2 releases.)
    I get no sound for these files no matter what I do. Obviously, pass through doesn't work, and I've tried various channels (2.0, 5.1, etc.) with no luck.
    I tried the sames files and configuration on an RPI running the same version of LibreELEC, OSMC (RPI and Vero 4K) and CoreELEC on an Odroid N2 - all work fine.
    It seems to be specific to the the Odroid C2.
    I haven't been able to boot CoreELEC on the Odroid C2, so not sure about it.
    Thanks.
  • I tried CoreELEC 9.0.3 on the Odroid C2 - audio works fine.
    So, PCM (or just FLAC and AAC to PCM) seems to have problems only on LibreELEC and only on the Odroid C2.
