Nightly images for A64, H3 and H6 boards
  • beelink wifi not working
    no need to open the box, just enter:
    1. cat /sys/bus/mmc/devices/mmc1\:0001/mmc1\:0001\:1/device
    if the reply is:
    1. 0xf179
    you are out of luck, as its the realtek version with crappy out of tree driver on GitHub...
  • What usb devices are supported for networking?
    I tried to enable all of them in kernel, but I maybe miss something. Just stay away from Realtek. Small number of Realtek devices is supported, but better to select almost anything else.
  • Hi guys!
    I cant find Nightly image for Orange Pi 3 on H6 chip.
    Does anyone have it?
    Board: Orange PI 3 H6 Quad-core 64-bit 1.8GHZ ARM Cortex-A53
    TV: TELEFUNKEN TF-LED65S75T2SU
  • Issue, when only one resolution was listed (1024x768) and no HDMI audio, should be fixed in next nightly. Boot time should be also quicker for 3 seconds.
  • any updates with hyperion/screengrabber on h3?
    PS link to previous thread in first message lead to new thread
  • jernej
    I noticed that when the TV where the Orange PC is connected is turned off, rebooting is not successful. Is it a CEC problem? Also using it as an FTP server, I would like to understand what the problem may be. Thanks
  • I noticed that when the TV where the Orange PC is connected is turned off, rebooting is not successful.
    How do you reboot board?
    When TV is turned off it sends CEC message to board, which should also turn off. But there might be a bug regarding that. You should be able to disable that in settings somewhere. Similarly, if you power on OrangePi PC when TV is off, TV should automatically turn on when Kodi is fully booted.
  • jernej hai bro, why image plus2e missing again? Hahahaha
    Someone want to install to emmc? If someone want it, i will be introduced step by step
  • why image plus2e missing again?
    I don't know, I don't have access to that part of infrastructure. I'll ask.
    You mean how to dd image to eMMC or something else?
  • You mean how to dd image to eMMC or something else?
    yes. Only default dd command to install it. But you must installing img file, not Trying copy paste file and install bootloader. Its always failed
    Edited once, last by hostkit ().
