No luck with the Pine64+ image either.
- dmesg | grep eth
- [ 0.000000] psci: probing for conduit method from DT.
- [ 11.917939] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
- [ 11.935933] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 6 (expect 0)
- [ 11.935962] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
- [ 11.935969] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
- [ 11.935976] dwmac-sun8i 1c30000.ethernet: COE Type 2
- [ 11.935983] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
- [ 11.935992] dwmac-sun8i 1c30000.ethernet: Normal descriptors
- [ 11.936000] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
- [ 12.017213] dwmac-sun8i 1c30000.ethernet eth0: Could not attach to PHY
- [ 12.017230] dwmac-sun8i 1c30000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
- [ 244.715743] dwmac-sun8i 1c30000.ethernet eth0: Could not attach to PHY
- [ 244.715763] dwmac-sun8i 1c30000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
- [ 248.698940] dwmac-sun8i 1c30000.ethernet eth0: Could not attach to PHY
- [ 248.698962] dwmac-sun8i 1c30000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
- [ 254.565973] dwmac-sun8i 1c30000.ethernet eth0: Could not attach to PHY
- [ 254.565995] dwmac-sun8i 1c30000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
- [ 292.732837] dwmac-sun8i 1c30000.ethernet eth0: Could not attach to PHY
- [ 292.732858] dwmac-sun8i 1c30000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
- [ 357.788378] dwmac-sun8i 1c30000.ethernet eth0: Could not attach to PHY
- [ 357.788395] dwmac-sun8i 1c30000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
- [ 360.068862] dwmac-sun8i 1c30000.ethernet eth0: Could not attach to PHY
- [ 360.068883] dwmac-sun8i 1c30000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
- [ 363.168764] dwmac-sun8i 1c30000.ethernet eth0: Could not attach to PHY
- [ 363.168785] dwmac-sun8i 1c30000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
- [ 418.603254] dwmac-sun8i 1c30000.ethernet eth0: Could not attach to PHY
- [ 418.603274] dwmac-sun8i 1c30000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
