Nightly images for A20, A64, H3, H5 and H6 boards
  • Code
    1. Hola, soy nuevo por aquí. Tengo una pregunta.
    2. ¿En este dispositivo puedo instalar libreelec?
    3. https://es.aliexpress.com/item/32999240962.html?src=google&albslr=202310162&albch=shopping&acnt=494-037-6276&isdl=y&slnk=&plac=&mtctp=&albbt=Google_7_shopping&aff_platform=google&aff_short_key=UneMJZVf&albagn=888888&albcp=1633820309&albag=63890294393&trgt=743612850874&crea=es32999240962&netw=u&device=c&gclid=Cj0KCQjwpavpBRDQARIsAPfTwiz3dU2_p2ZB32gznPPsz1jvY6JkHp6UgxMHg1cXk0N4KlXHs03GV4YaAmg4EALw_wcB&gclsrc=aw.ds
    4. Thanks in advance. a greeting
  • I just did a clean build for H6 (OrangePi 3, I don't have One+) and it works, except 4k H264, which I will look into later. Not sure what could be wrong, since only U-Boot and DT differ between these two and DTs are almost the same.
    Thanks, OPi-3 build (2019-07-13) works OK* on OPi One+ with dtb replaced (U-boot intact)
    *576 streams don't show the video with OK sound.
  • Hi, I have one question: Is it possible to create a tar update file from img.gz image? Or another way?
    Thanks for your work.
    It is, but for some time now you can also use .img.gz file for updating too (it's just a bit slower), so img.gz is actually the only needed format.
  • I have tried latest build LibreELEC-H3.arm-9.80-nightly-20190718-0b82779-orangepi-pc.img for OPI PC, seems not working USB gamepad.
    Tested with SNES gamepad. Can not assign any button.
    Yes , system reported as Linux 5.2.0, so new kernel.
    Well, i have a same trouble. Sega, nes and ps1-ps2 usb gamepads not working. I wan't use ROPi's images, like this Libreelec.
    ps I have Raspberry 2 and same version Kodi and usb gamepads work by default.
    Do you have any luck with latest build?
  • Hey, guys!
    Has anyone installed Plex Media Server on LibreELEC? Is that even possible?
    Board: Orange PI 3 H6 Quad-core 64-bit 1.8GHZ ARM Cortex-A53
    TV: TELEFUNKEN TF-LED65S75T2SU
  • which driver would be needed for that? I mean exact kernel config line.
    Unfortunately I can't definitely say. Sorry.
    This is my devices list:
    In console I can get response from gamepad via simple cat /dev/input/by-id/usb-0810_usb_gamepad-event-joystick:
    I googled on this subject and maybe it is joydev module we are looking for?
    1. LibreELEC:~ # modprobe usbhid
    2. LibreELEC:~ # modprobe joydev
    3. modprobe: FATAL: Module joydev not found in directory /lib/modules/5.2.0
    I'm far from an expert in the Linux kernel, sorry again.
  • I googled on this subject and maybe it is joydev module we are looking for?
    So CONFIG_INPUT_JOYDEV, which indeed is not enabled. Most other projects have it enabled. I'll add it in next PR.
  • I can't connect Panasonic TV via HDMI-CEC (Viera Link).
    Board: Orange Pi Plus
    LibreElec: 20190718
    Where i should search a problem?
