Control volume in Kodi via CEC using Sony Remote control
  • Hello,
    I'm running the latest version of LibreELEC (9.0.1) on an AMD based computer which is hooked up to a Sony Bravia KDL 60ex705 using HDMI. In addition there is the PulseEight CEC Adapter connected to a USB port of the computer. Waking up, sleep mode, and controlling Kodi works without problem. However when using the volume buttons on the remote instead of changing the volume of Kodi the volume of the TV set is changed. As a workaround I'm now using the HDMI port of the PC as audio channel. The analog audio signal generated from the TV is then fed into an amplifier and to external speakers. Is there anything that can be done to have the remote command change the volume in Kodi? What information could I generate or inspect to find a fix?
    Thank you
    PS I forgot to mention that this way I can only use stereo signals generated from the TV.
    Edited once, last by bnebenda (April 17, 2019 at 1:38 PM).
