Hi,
I just installed LE 9.0 on an Intel NUC and have the following problem:
When I press the power button of my USB remote (air mouse + keyboard, it is detected as a USB keyboard and mouse) the system immediately suspends.
I can see the power menu popping up and then the screen goes blank. After powering up again, the shutdown menu is still displayed and I can shutdown the system.
Is there any way to prevent the immediate suspend so I can use the shutdown menu?
I guess the remote triggers a suspend event and brings up the power menu, but I have no idea where to disable the suspend.
It would also be okay for me to disable suspend completely if it helps.
Thanks.
