Test LE images with Kodi-19 for S9xxx
  • Quote from balbes150
    Can you show UART log ?
    GXBB:BL1:08dafd:0a8993;FEAT:EDFC318C;POC:3;RCY:0;EMMC:800;NAND:81;SD:0;READ:0;CHK:F3;USB:8;LOOP:1;EMMC:800;NAND:81;SD:0;READ:0;CHK:F3;USB:8;LOOP:2;EMMC:800;NAND:81;SD:0;READ:0;CHK:F3;USB:8;LOOP:3;EMMC:8;
    I temporarily stopped building aarch64. What exact version of the image was used ?
    I did a git pull today on your amlogic-master branch. Compiling (ARCH=arm) leads to the same result as above.
  • Hello friend, I have a doubt that I recently installed these programs recently purchased an Amlogic S905X2 Android 9.0 T95Q 4GB RAM 64GB ROM Quad core
    What programs are for this model?
    thank you
  • tks for the info... but my android does not have menu update.. can you share android or linux command, so i can update aml_autoscript.zip manualy?
  • In Kodi of the Android, the system informations display 4 Gb
    LE correctly shows the real memory size. In Android firmware manufacturers often specifically deceive users, overestimate the real memory size.
    Show the UART log from the launch of my latest build 20190724. Self-Assembly from GIT can be different.
    img.gz
  • A95x f2 issues:
    1. When installed to emmc goes to bootloop after the first reboot.
    2. Cpu cores 0 and 1 constantly loaded from 40 to 90%.
    Dtb used is x96rmii. Only this one allows ethernet to work along with the internal memory to be seen
    Edited once, last by Patkino ().
  • Hello,
    I've booted the latest image on my A95X F2 (s905x2) with 4Gb of RAM / 64 Gb of emmc.The first issue is the amount of RAM: only 3Gb are available.
    Worst, Kodi crashed when I try to play a x265 video with hardware acceleration activated. I've tried all g12a dtb with no success.
    Could you please tell if it is possible to change the hardware acceleration driver?
    Which video sample are you using? I'd like to try it....
  • the wireless doesn't work with this........and the wired only works if you disable the wireless /shrug
    also the reboot doesn't work.....I see the linux output on the screen, gets to 'Reached target Reboot.' but it doesn't reboot....
    This DTB I am only interested in working eMMC (installing to eMMC).
    Maybe try installing Terminal Emulator under android. Then rinsert SD card, run the TE app and type "reboot update" and enter. That may work.
  • Thank you and what is the ram folder for 4gigas for this model
  • This DTB I am only interested in working eMMC (installing to eMMC).
    As far as I have noticed, libreelec sees internal storage on a95x f2 only at first boot,not depending on dtb.
    That's why it goes to bootloop after reboot
  • I tried this version LE on Mecool KM8 S905X 2G/16GB, new version with wifi/bt chip AP6236
    wifi/bt no working, dtb or missing driver issue?
    AP6236
    BCM43436B0
    Remote also does not work
  • wifi/bt no working, dtb or missing driver issue?
    AP6236
    BCM43436B0
    As BCM43/CYW43 are usually very well supported, I guess it's a dtb issue, but without further info it's hard to guess.
