Hello, I am not shore if this is right place where to post, but here it goes.
I had a problem that I wanted my MCE remote Power button on Libreelec RPI3 Kodi 18, to turn off screen (HDMI) but keep running for samba, transmission etc.![]()
If kids accidentally pressed MCE power button system was powered off.
So what I did:
1. Install Power Display screen saver - http://github.com/asavah/script.pidisplaypower
2. Select Power Display as active screen saver
3. Install Key Map Editor addon http://kodi.wiki/view/Add-on:Keymap_Editor
4. Edit some key and save (so gen.xml file is created)
5. Modify gen.xml (you can access it via Libreelec Samba) by deleting all that was saved in userdata/keymaps/gen.xml and copying this in gen.xml:
<?xml version="1.0" encoding="UTF-8"?>
<!-- This file contains the mapping of keys (gamepad, remote, and keyboard) to actions within XBMC -->
<!-- The <global> section is a fall through - they will only be used if the button is not -->
<!-- used in the current window's section. Note that there is only handling -->
<!-- for a single action per button at this stage. -->
<!-- For joystick/gamepad configuration under linux/win32, see below as it differs from xbox -->
<!-- gamepads. -->
<!-- The format is: -->
<!-- <device> -->
<!-- <button>action</button> -->
<!-- </device> -->
<!-- To map keys from other remotes using the RCA protocol, you may add <universalremote> blocks -->
<!-- In this case, the tags used are <obc#> where # is the original button code (OBC) of the key -->
<!-- You set it up by adding a <universalremote> block to the window or <global> section: -->
<!-- <universalremote> -->
<!-- <obc45>Stop</obc45> -->
<!-- </universalremote> -->
<!-- Note that the action can be a built-in function. -->
<!-- eg <B>ActivateWindow(MyMusic)</B> -->
<!-- would automatically go to My Music on the press of the B button. -->
<keymap>
<global>
<remote>
<play>PlayPause</play>
<pause>Pause</pause>
<stop>Stop</stop>
<forward>FastForward</forward>
<reverse>Rewind</reverse>
<left>Left</left>
<right>Right</right>
<up>Up</up>
<down>Down</down>
<select>Select</select>
<pageplus>PageUp</pageplus>
<pageminus>PageDown</pageminus>
<back>PreviousMenu</back>
<dvdmenu>PlayDVD</dvdmenu>
<info>ContextMenu</info>
<skip>StepForward</skip>
<replay>StepBackward</replay>
<record>Record</record>
<volumeplus>VolumeUp</volumeplus>
<volumeminus>VolumeDown</volumeminus>
<mute>Mute</mute>
<power>ActivateScreensaver</power>
<myvideo>ActivateWindow(MyVideos)</myvideo>
<mymusic>ActivateWindow(RadioChannels)</mymusic>
<mypictures>Screensaver</mypictures>
<mytv>FullScreenVideo</mytv>
<guide>ActivateWindow(TVGuide)</guide>
<livetv>ActivateWindow(TVChannels)</livetv>
<recordedtv>ActivateWindow(TVRecordings)</recordedtv>
<red>Red</red>
<green>Green</green>
<yellow>Yellow</yellow>
<blue>Blue</blue>
<zero>Number0</zero>
<one>Number1</one>
<two>Number2</two>
<three>Number3</three>
<four>Number4</four>
<five>Number5</five>
<six>Number6</six>
<seven>Number7</seven>
<eight>Number8</eight>
<nine>Number9</nine>
<clear>Delete</clear>
<enter>Enter</enter>
<thegreenbutton>ActivateWindow(Home)</thegreenbutton>
<teletext>info</teletext>
</remote>
</global>
<FullscreenVideo>
<remote>
<left>StepBack</left>
<right>StepForward</right>
<mytv>CodecInfo</mytv>
<star>NextSubtitle</star>
<hash>AudioNextLanguage</hash>
</remote>
</FullscreenVideo>
<Visualisation>
<remote>
<left>PreviousPreset</left>
<right>NextPreset</right>
<up>IncreaseRating</up>
<down>DecreaseRating</down>
<back>Back</back>
<title>CodecInfo</title>
<select>ActivateWindow(VisualisationPresetList)</select>
<menu>OSD</menu>
<contentsmenu>OSD</contentsmenu>
<rootmenu>OSD</rootmenu>
<start>OSD</start>
<info>Info</info>
<guide>ActivateWindow(PVROSDGuide)</guide>
<playlist>ActivateWindow(PVROSDChannels)</playlist>
</remote>
</Visualisation>
<VirtualKeyboard>
<remote>
<clear>BackSpace</clear>
<star>Shift</star>
<hash>Symbols</hash>
<one>Number1</one>
<two>Number2</two>
<six>Number6</six>
<left>CursorLeft</left>
<right>CursorRight</right>
</remote>
</VirtualKeyboard>
<NumericInput>
<remote>
<one>Number1</one>
<two>Number2</two>
<six>Number6</six>
</remote>
</NumericInput>
<Teletext>
<remote>
<teletext>Back</teletext>
</remote>
</Teletext>
<FullscreenLiveTV>
<remote>
<up>ChannelUp</up>
<down>ChannelDown</down>
<pageplus>ChannelUp</pageplus>
<pageminus>ChannelDown</pageminus>
<teletext>ActivateWindow(Teletext)</teletext>
</remote>
</FullscreenLiveTV>
<FullscreenRadio>
<remote>
<up>ChannelUp</up>
</remote>
</FullscreenRadio>
</keymap>
Display More
6. Save changes
7. Reboot and all works as it should
A lot of credit goes to Power Display screen saver and friendly OSCM forum post - OSCM post by user baloan
Hope it helps to other RPI Libreelec users!
